Home › Forums › Products › Stompboxes › TimeFactor XMT Map stops sending MIDI message
April 14, 2014 at 5:57 am #111532
ericberumen
MemberI run my Line 6 M9 slaved to my TF. The TF has a MIDI cable going from it's OUT to the IN of the M9. It works perfectly from 1:1 all the way up to 12:1……after that the M9 no longer receives MIDI messages from TF. This is no bueno.
Can any staff members help with this?
April 14, 2014 at 6:18 pm #125720
Unclear what MIDI messages you are talking about. Assuming that you mean Program Change, look at the TX MIDImap and make sure it shows what you would expect.
April 14, 2014 at 6:36 pm #125722
ericberumen
MemberYes a program change. Every TF preset up to 12:1 changes the scene on the M9, but why does it stop changing the scene at 12:2?? I checked the Rec MAP and the XMT Map and I assigned each preset starting from MIDI program number 1 to 100. IE: 1:1 = 1 1:2= 2 and so on…..
April 14, 2014 at 7:15 pm #136464
I think this may be an issue with the M9. The fact that, as far as I know, the M9 only has 24 (4*6) patches and it stops working at 12:2 suggests that this may be the case.
You should probably talk to them – we are not experts on their fine products.
See also http://forum.tcelectronic.com/topic/7498/gsystem-line-6-m9-are-they-midi-compatible/ for more discussion on this topic, especially the comment by Mr jaded1592.
April 14, 2014 at 7:47 pm #136468
ericberumen
MemberAH! Well that makes sense! Geeze. Thanks so much.
April 29, 2014 at 4:21 am #136539
ericberumen
MemberOk. Now another problem. My Timefactor used to send BPM clock to my M9. That is no longer the case. What setting do I need to change? Thanks in advance.
April 29, 2014 at 3:38 pm #136543
Make sure MIDI/OUTPUT is set to XMT and MIDI/CLK OUT is set to ON.
April 29, 2014 at 8:55 pm #136544
ericberumen
MemberThose setting were as you suggested. What else could it be? Also what is CLK FLT?
April 29, 2014 at 9:07 pm #136545
Can't think of anything else. Check cables and M9 settings.
CLK FLT is a filter used when you are receiving a bad MIDICLOCK.
April 29, 2014 at 9:19 pm #136546
ericberumen
MemberI suspect the cable too. Any brands you recommend for MIDI cables? Thanks so much for the help.
April 30, 2014 at 4:59 pm #136548
MIDI cables are fairly uncritical unless they are long. The main risk is that what looks like a MIDI cable may be mis-wired, broken, or some kind of incompatible audio cable.
