In the paralles effects loop of a Marshall JVM205H I'm having the following issue:
Marshall sounds fine without loop and also sounds fine when loop is engaged and one of the TIme Factor's presets are active. Howev, with the loop engaged and the time factor on bypass the sound goes really think and maybe a bit lower in volume.
I'm using the unit at line level with a +4 from the amp (compared to the -10db option)
and the TF is set to bypass that allows delays to spill over.
Is there something in the TF settings that needs to be changed so this tone kill doesn't happen when it's bypassed?
