Home › Forums › Products › Stompboxes › Tom Scholz Rockman Boston Tone
- This topic has 8 replies, 1 voice, and was last updated 1 year, 10 months ago by
Fretfire6.
November 8, 2017 at 3:02 pm #114451
I am wondering if anyone has used the H9 to get a Tom Scholz Rockman Boston Tone? If you could share your settings and experiences I would appreciate it.
November 23, 2017 at 3:39 pm #147724
I am with you on this pursuit. I just watched guitarinteractives great overview of the pitchfuzz algo and am thinking it might get close as early on I could hear the basic distortion flavor. Add pitch to get the chorus and a little short delay and it might be the core. Might still have to play with an EQ and compressor. Tom’s Graphic band EQ was pretty extreme. If I recall he really boosted 400 and 800. I had a Boss OD20 which had a ‘Rockman’ model but it was garbage. I used to own the X100. I think I will boilerplate Don’t Look Back as it has a lot of the tonal colors I like. Keep me posted and I will do the same. An elusive sound to be sure and 8 am feeding a Vox! So I have my work cut out for me! Gonna hitch a ride on the Eventide….
November 24, 2017 at 9:53 pm #147743
Ok – trying to match to ‘Don’t look back’. Far from perfect but actually I like the sound nonetheless.
First off here is my setup.
A. I don’t own a Les Paul. So closest I have is my SGish Wechter with SD trembuckers bridge and reverse ’59 in the neck. For the main opening riff I actually set my humbucker in parallel which seemed to add a little definition but overall used the series as it sounded better for the lead lines.
B. I did use my analog alien Joe Walsh Double Classic compressor at about 4:1 ratio into my Full Drive 2 set with just bit of clean boost into the preamp of my nighttrain G2.
C. I ran the H9 as ‘post’ which I have in my FX loop with settings shown. I created the expression to toggle for the bridge neck humbucker darker sound. What I discovered is that my normal splash of reverb on my amp was too much and I really dialed it back to cleanup the definition.
I consider this a starting point. I am still thinking an EQ in there might get it closer
Let me know what you think. In my rig I do love the way the chords sustain and tail off. -
November 25, 2017 at 8:00 pm #147751
Took the fulltone out of the path. Upped the preamp gain and increased the top fuzz to 42. Voices to 1.0 pitch to -10 and + 10 and turned off delay 2. Better.
November 27, 2017 at 7:42 pm #147762
This looks cool I will try it out and get back to you
December 1, 2017 at 12:42 pm #147790
Seems pitchfuzz could do what this does – at least series option. https://www.oldbloodnoise.com/pedals/excess-distortion-chorusdelay.
August 13, 2018 at 8:36 pm #149906
Nice suggestions I am going to give them a try tonight.
August 19, 2021 at 2:53 am #158428
Hey there good people. I thought I’d revive this thread since I’m new to the H-9 and also trying to nail that signature Boston tone & harmonies too.
Any help with settings or presets would be much appreciated.
Thanks
June 9, 2023 at 10:52 am #171839
I play in a Boston tribute band and I use a pretty simple set-up to replicate Scholz’s tone.
A Dunlop Q-zone pedal for the “parked wah tone” gets me the rhythm guitar tone. It works well because I can blend the wet-dry signal in order to not have the effect becoming too overwhelming.
For the harmonized solo parts, I use an Eventide H9 with pre-programmed settings in a loop that I activate w/a momentary looper pedal. I apologize for not sharing the exact details of the settings. I need to keep things somewhat ambiguous. I hope you understand.
