I use it. My tone is monster. I have noticed no issues. And are you sure it converts twice? If i were eventide..I’d use true bypass on the unused I/o. I’ve never looked into it though. .
I am sure that it does A/D/A conversion twice since this is something that have been discussed earlier in this forum.
If i remember correctly DSP bypass is used in pre/post mode. There are no separate relays for every ins and outs, so it’s not possible to bypass only one side of the pedal with relay bypass.
If i remember correctly DSP bypass is used in pre/post mode. There are no separate relays for every ins and outs, so it's not possible to bypass only one side of the pedal with relay bypass.
This is correct. The hardware was designed long before we implemented pre/post.
