Transmit key signature via midi with pitch factor
Home Forums Products Stompboxes Transmit key signature via midi with pitch factor
    • #106784
        Hi all, I have a question for pitch factor user:is possible to send the key signature with midi out from pitch factor to miodi in of another rack? thank for the answer.
      • #119799
          Not sure what you mean by "key signature" in this context.
          If you mean the key setting of the Diatonic you could use that knob to send a CC if you were setting it manually, but this is probably not what you have in mind.
        • #119925
            i mean the key generated from the button "learn"…
