Tremolo and delay ?
Home › Forums › Products › Stompboxes › Tremolo and delay ?
Viewing 4 reply threads
    • #116056
      Chalky
        I have two songs that need tremolo and delay. The TUMBLEWEED preset is perfect for the tremolo but it doesn’t offer and delay, and I can’t see anywhere else where I can combine the two. Can anyone help.
      • #155604
        bohan
          No sure if you can find the sound you want, but you may try Undulator, SpaceTime and Mod Delay algorithms
        • #155606
          Chalky
            Thanks Bohan I did try those and even went through the Algorithm manual but no … I suspected I couldn’t get what I wanted but hey, thanks for replying
          • #155607
              I was thinking UltraTap.  Tremolo, using the CHOP / SPEED parameters (upstream), in series with the UltraTap delay line.  I’m not sure what your delay requirements are, but UltraTap is highly configurable.
              You can use the LENGTH knob (and/or PRE-DELAY) with as single TAP.  Or simulate a FEEDBACK parameter on a standard delay pedal with multiple TAPS, a positive TAPER, and an extended overall LENGTH.
            • #156321
              Chalky
                Spring / ‘Spring Theory’ offers a decent Trem’ + reverb … it’ll do for now. Thanks everyone! 🙂
