Tremoloverb adding up predelays- Bug or Feature?
Home Forums Products Stompboxes Tremoloverb adding up predelays- Bug or Feature?
    • #114133
      camn
      Hey-
      I am running into a wierd thing.. I can’t figure out whats the deal
      Maybe its a bug?
      Maybe its normal?
      Maybe its my setup?
      Anyway it is this:
      IN TH H9 CONTROL:
      Choose Tremoloverb. I used the “tremoloverb” preset in the “tremoloverb” algo to get there.. but I have reproduced it on a few prestets in that Algo.
      Set it to BPM Tempo mode.
      Now.. set the PREDELAY to something. I want 1/8.
      Then Hold down the Hotswitch to make it blink. Drag the PREDELAY to zero. Press the Hotswitch again.
      What I expect is for the hotswitch to toggle values. OFF to 1/8 to OFF to 1/8.
      BUT when I toggle…  Mine start piling up. 1/8–>NONE–>1/4t->NONE–>1/4->NONE–>1/2t->NONE–>7/16->NONE–>etc etc until it gets to the top.
      I do NOT observe this behavior with tempo OFF.. it just toggles, Like I would expect.
      Can I fix this? I want predelay OFF during verses.
    • #146266
      wedelich
      Hi camn,
      Sounds like a bug to me.  I remember there being bugs in the H9 Control Tremoloverb at one point that we fixed.  Are you on the latest version? Also is this iOS, MacOS, Windows?
      FWIW, in a quick test on MacOS, I can't duplicate it using the latest H9 Control in demo mode (not connected to an H9).
    • #146271
      camn
      Hi!
      Its on the PC version.. and I CAN reproduce it in demo mode.
      BUT- I just checked in IoS- and it doesn’t happen there.
      So I assume it isnt actually happening in real life while performing- so we are good, and there is no problem!
      c
