Home › Forums › Products › Stompboxes › Tricerachorus and Blackhole connecting issue!
- This topic has 9 replies, 2 voices, and was last updated 2 years, 2 months ago by joecozziEventide Staff.
November 22, 2022 at 8:04 pm #166978ErickMercuryParticipant
HellO ::
I am wanting to connect the Tricerachorus stereo OUT to TRS cable INPUT to Blackhole.
I notice that when Black hole is n bypass the chorus sounds not stereo and almost gone on the right side of the stereo field.
Does the Chorus ‘have’ to be in a mono setting? Why can’t I have the stereo of the Chorus pedal with the Blackhole reverb in stereo as well?
I am using a TRS 1/4 cable. Please help..
November 22, 2022 at 8:10 pm #166979
Hi ErickMercury,
Is your Blackhole set for stereo operation?
November 22, 2022 at 8:31 pm #166980ErickMercuryParticipant
yes.
stereo button is on from Tracer and stereo button is on for blackhole.
Two 1/4 cable out to 1/4 trs stereo ( same chord splitter)
into the input and two 1/4 out from blackhole to mixer for left/right
November 22, 2022 at 8:32 pm #166981ErickMercuryParticipant
How can I connect true stereo Tricerachorus into the true stereo of the Blackhole?
Is there specific TRS cables needed?
November 22, 2022 at 8:35 pm #166982
yes. stereo button is on from Tracer and stereo button is on for blackhole. Two 1/4 cable out to 1/4 trs stereo ( same chord splitter) into the input and two 1/4 out from blackhole to mixer for left/right
Are you connecting your guitar to TriceraChorus first because if you are, TriceraChorus’s input should be set to mono, not stereo.
November 22, 2022 at 8:38 pm #166983
How can I connect true stereo Tricerachorus into the true stereo of the Blackhole? Is there specific TRS cables needed?
Any insert cable (TRS to dual TS) from Tri-C to Blackhole will do. Regular 1/4” cables from Blackhole to your console will work. But again, if you’re connecting to TriceraChorus’s input, that cable needs to be TS and the pedal’s input should be set to MONO.
November 22, 2022 at 8:42 pm #166984ErickMercuryParticipant
ok so if I want to connect another processor that has two outputs (boss gt 100) to the Tricera…Ill need TRS cables for this I want to the stereo out put of the floorboards to also be aligned with stereo input of the Tricera (stereo button on?) and then TRS cable to Blackhole (stereo button on?)
November 22, 2022 at 8:46 pm #166985
Yes.
November 22, 2022 at 8:48 pm #166986ErickMercuryParticipant
lastly – and thank you for helping with this.
Any recommendation for the appropriate TRS spot cables Eventide would recommend?
November 22, 2022 at 9:26 pm #166988
There isn’t an official Eventide recommendation but I like using:
Creation Music Company: https://creationmusiccompany.com/collections/trs-dual-mono-patch
West Coast Pedalboard: https://westcoastpedalboard.com/product/trs-to-dual-mono-insert-cable/
EBS Flat patch: https://ebssweden.com/content2/accessories/patch-cables-connectors/
