Tricerachorus Clipping Sound
Home Forums Products Plug-Ins Tricerachorus Clipping Sound
    • #116517
      robinibbo
      I bought the Tricerachorus plugin this morning and it is making strange percussive sounds when I play my guitar through it, all the presets have it.
      Tried both the VST3 and VST2, both are the same.  I have uninstalled, reinstalled, rebooted, tried 3 different DAWs and AMP sims with no difference.
      Setup as follows:
      • BiasFX2 with basic compression, eq, amp and cabinet, the signal is pristine clean with no clipping.
      • Studio One 5 Artist, the problem also exists using Bandlab Sonar and Mulab.
      • Windows 10 Home version 19042.985 16Gb Ram and Samsung Evo SSD, Realktek onboard sound.
      • ASIO4All v2 drivers (medium sample rate), however the problem also present using Windows Audio drivers.
      • Guitar interface is an iRig HD which I have used without issue for years, my guitar is a Pacifica with passive pickups.
      Anyone any ideas or other troubleshooting I could try?
    • #157954
      Hi sorry for your issue.
      Since you've already submitted this issue to support@eventide.com a support ticket has been created and you will be responded to there shortly.
      Thanks,
      Tyler
