Tricerachourus Noisey when #2 output used!
Home Forums Products Stompboxes Tricerachourus Noisey when #2 output used!
    • #187440
      Jimijamed67
        My pedal works and sounds fine when using #1 channel, got a chance to try two amps, second channel very noisey, what is the issue, tried different cables, no success!
      • #187441
        joecozzi
          Can you describe the noise?
          Are the amps the same?
          Are you running both amps clean or with some preamp drive?
