TROUBLE WITH MIDI PROGRAM CHANGE
Home › Forums › Products › Stompboxes › TROUBLE WITH MIDI PROGRAM CHANGE
Viewing 13 reply threads
    • #109624
      Good Morning, i'm Simone from Italy… First of all excuse me for my bad english!
      I have trouble with modfactor program change
      -> I connect (by midi cable) my midi program change pedalboard (Vintek TB10) to a modfactor.
      The modfactor outpug goes in to my new timefactor,
      -> If modfactor midi output is set on THRU, program change works good : for example If i press preset 2 on my midi pedalboard modfactor goes on preset 1:2 and also timefactor changes in the same preset number. In this way the modfactor clock setting are not trasmitted (and this is correct because output is thru).
      -> But I need to transmit the clock stored or tapped on modfactor to timefactor so i set the modfactor midi output XMT… and here comes my trouble:
          – modfactor recive program change send from midi pedalboard
          – timefactor recive clock changes from modfactor
          – timefactor don't recive program change send from midi pedalboard (…timefactor recive program change only if program change is setting pressing the modfactor's button but this function isn't good for my setup)
      There is a way to correct this problem or is possible to set the modfactor output XMT+THRU?
      I hope my exposition is clear and you can understand my trouble
      Tank you very much, i hope in your kind answer
      Best Regards
    • #124319
        The Factor pedals must be in either XMT or THRU. You can do what you want by using a "MIDI Merge" box from a company like Midi Solutions.
      • #124320
        luedmo
          Hi Nick
          I have a similar problem to Simone, but am also trying to transmit CC as well as Program Changes and clock TAP etc..
          Can you give a clear example of how the MIDI merge box would work? (i.e. which pedal goes into what box what with which settings – XMT, THRU etc.)?
          That'd be very helpful for MIDI-novices such as this one here.
          Many thanks!
          :Lu
        • #135253
          jhyman
            Hi Lu,
            Check out the following link, which should help.
            http://forum.eventide.com/cs/forums/p/7331/32868.aspx#32868
            jerome
          • #135254
            luedmo
              Many thanks for that Link!
              …and full respect to BMF for the diagrams showing how to use MIDI split/merge devices Yes
              :L
            • #124333
              Many thanks to those who helped me… I don't use "midi" a lot and I did not know all these possibilities.
              I've always considered Eventide as THE LEADER …. nothing sound as Eventide… So now, sincerly, I'm shocked Tongue Tied … I can't belive that function can't do inside the stompbox's software
              The external midi connection takes a lot of space in pedalboard and a lot of money
              How much is a stompbox software update that enable Thru+xmt? If it's possible a prefer pay an update rather do lot of external connection
              Simone
            • #124335
                Sorry – most stompboxes don't have MIDI at all, and I'm certainly not aware of one that has a merge feature (100 people will now prove me wrong).
                We think about adding this to a future update, but it may not be possible. At any rate we have nothing available at the present time.
              • #135262
                luedmo
                  Hi Simone,
                  I will soon have a <midisport 2×2> box and will tell you about my progress.
                  Agreed, a MERGE feature would be useful but at least we have a solution now
                  For gigging I have anyway decided that the TRS "Aux SW" switches are very reliable – so I keep them
                  Then to have deeper MIDI control – well, vedremo come va…
                  :L
                • #135269
                  Did you get the MIDISport yet?  I am wondering about supplying power to it since it says it is powered by USB.
                • #135270
                  luedmo
                    Hi Steve,
                    Yes it works and yes it needs USB.
                    I attached the pedals just as badmelonfarmer suggested. Followed the instructions 🙂
                    I now use my little Digitech 3-button pedal for AUX SW functions going out on CC and I use the main Space switches for banking up and down i.e. < ACT, BK+ and BK- > because a Space already has BK+ and BK-). The MIDI controller also works so that means CC access into the nether reaches…
                    Thanks again to Jerome and BMF for all their help!
                    :L
                  • #135272
                    Maybe this is a silly question where do you get USB power on your pedal board?  Or are you using this with a computer set up instead of a live pedalboard?
                  • #135274
                    luedmo
                      Hi
                      Live pedalboard no computer.
                      I found a second-hand USB charger in my local market – the shape of a UK mains plug with a USB output (made possibly by / for Mac?) I think one gets these for iPhones etc. with the usual Mac international plug adapter ends, and I like it because it has a very small footprint.
                      That begs the question "what if it goes down"? So I am training myself to understand how to dig into the Clock-Factor and reset it so it works with just the triple AUXsw. There be some weirdnesses otherwise…
                      How are you planning to set up the CC's?
                      :L
                    • #135275
                      Or course!  That makes sense for a USB charger.
                      I have not thought as far as CC yet.  That will need some reading and trial and error.  I just want to play with Expression and Tap Tempo over all 4 pedals.  Although it's not realistic to change all pedals at the same time with Expression pedal.  But fun to play with.
                    • #135276
                      luedmo
                        ..in my case way more error than trial Wink
                        As for what you say about the expression pedal I have noticed a parameter in the SYSTEM menu "MIDI > RCV CTL" which allows you to set PEDAL to a CC" – have you tried that yet?
                        It suggests to me that you could set up that PEDAL parameter to different CC numbers on each pedal and then try out the MIDI controller expression pedal to those CCs and see if you can access one or more stompbox's knob parameters *as if* there were an expression pedal attached.
                        Well, that's optimism for you. Good luck let me know how it goes
                        :L
