TRS–>MIDI DIN for the H90
Home › Forums › Products › Stompboxes › TRS–>MIDI DIN for the H90
    • #187642
      dror.shiman
        Hi guys,
        I want to connect an external MIDI controller to the H90. The device has a TRS MIDI output, but the cable I’m using doesn’t seem to work. I suspect the wiring might be incorrect.
        Can you advise on the correct way to solder a TRS to DIN cable for the H90?
      • #187654
        PH68
          There are two types of TRS Midi: Type A, and Type B
          Eventide use Type A
          Here’s some decent info including wiring diagrams…
          [Updated] How to Make Your Own 3.5mm mini stereo TRS-to-MIDI 5 pin DIN cables
        • #187696
          tsternfeld
            DIN is the more standardized MIDI jack, and we use the standard 5-pin DIN pinout.  How you correctly wire your TRS-DIN cable will depend on which TRS standard your MIDI controller follows.
