Trying to control H90 with Morningstar MC6 Pro
Home Forums Products Stompboxes Trying to control H90 with Morningstar MC6 Pro
    • #173095
      zambiland
        I’ve been setting up the MC6 Pro to control the H90 as well as a Future Impact. It’s working out pretty well, except that when I send a program change to call up a certain program, everything freezes. I can’t find anything anything out of the ordinary in the MC6 Pro, so I’m wondering if there’s something behind the scenes that is causing this.
        Also, I have set up foot switches to control overall on/off, effect A on/off and effect B on/off. It works but the LEDs on the H90 only reflect the on/off status with the master on/off. Am I sending the wrong kind of messages to the H90 for the individual effects?
        TIA!
      • #173096
        joecozzi
          How do you have things hooked up? What’s first in the chain? Are you using DIN MIDI?
          You won’t see the states in SELECT mode. In PERFORM mode, if you have the switches assigned to act/byp the screen tabs will reflect the state by saying either Active or Bypass and the LED buttons will light up or not.
        • #173097
          zambiland
            Thanks for the reply! I have the H90 connected directly by USB. The FI is connected by DIN.
