Home › Forums › Products › Stompboxes › Trying to get MXR-117 Flanger sound
- This topic has 10 replies, 2 voices, and was last updated 1 year, 11 months ago by
cestlamort.
June 16, 2015 at 8:23 pm #112631
I have been trying and trying and can not replicate the classic Van Halen ” Unchained ” sound on the H9. I can get kind of close…. but not really. I want it to have the oscilating from top to bottom and back sound…. If you know a setting…. please post it. The setting on the MXR-117 is all knobs basically at 12oclock.
Thanks,
Daren
June 17, 2015 at 4:48 pm #139392
We have a factory preset built in that emulates the Ain't Talkin 'bout Love sound so maybe start there and see if that gets you closer. I've included an image of the setting in H9 Control.
June 17, 2015 at 5:58 pm #139393
I have tried that one…..it is a really good setting for phaser but not for the classic “unchained” flanger that is a distinct sound. I have looked through all the VH presets and did not find anything. I feel like it should be able to do it but can not get it there. The sound is a FAT sound with a chug chug chug that starts high and goes low and back…….
June 27, 2015 at 2:10 am #139475
Here’s something to dial in. I took the settings from a “hard-wired” MXR flanger – all knobs at 12:00 o’clock.
Keep the SPEED between 0.10 Hz. and 10 Hz. to be accurate. MODFY DLY O/P isn’t calibrated in milliseconds, but between 0.5 and 16 ms. is the correct range. If you’re feeling experimental, you can use the Vintage or Mod Delay algorithms.
September 10, 2015 at 12:29 pm #140491
I really appreciate it!!
March 28, 2016 at 5:18 pm #143023
Below’s my attempt at EVH’s UNCHained preset. FYI, I run the H9 in the fx loop of my EVH LBX head, into a 4×12.
March 28, 2016 at 10:08 pm #143029
The image in my previous post shows only half of the preset parameters, here’s both images…
April 28, 2023 at 9:28 pm #170736
Digging up another old thread to check if there are any updates or refinements for replicating the old (Reticon chip) MXR 117 Flanger, as used on Early Van Halen recordings. Thank you.
Also just letting Axessmario know that his preset images on the thread aren’t visible. Thank you -
April 30, 2023 at 4:14 pm #170747
Most of the images disappeared from posts when Eventide updated the forums.
I used one of Brock’s presets above to try to replicate my M117 (old model) sound, although I wasn’t after the EVH stuff (and I’m honestly not that familiar with it, as I lean more toward the clove cigarettes, fog machines and pointy shoes than spandex and sneakers from that era. Big hair in either case though!)
I haven’t been able to get the H9 / H90 to sound as substantial or “chewy” as the real deal, which has just has more churn/heft/body to the sound than the H9, which is more swirly than churny, if that makes any sense. I suspect than an eq with an emphasis on the low-mids would help in that regard. I lean heavily on the MXR so I continue to use the 117 or a (reissue) micro flanger live. I discovered that I’m really picky about flangers and have gone through a few to try and replicate the sound I like in the MXR, and everything has come up short, but the H9 comes closest. (see “tangent” below).
I’ve attached the preset I edited here. I found that it is really helpful as you’re dialing it in to assign one of the parameters to the expression pedal and sweep through it as you’re playing to find where it sounds best. I also got fancy and put both the original MXR and the H9 in a boss LS-2 and switched back and forth. (I did a similar thing to try to replicate a CE-2. The fun starts when you get close and then hit the gas / engage light speed with the Eventide to take it somewhere else).
Notes from when I first made it:
Attempt to knock the old, cranky MXR Flanger with a sketchy foot switch and volume drop off my board. Based on MXR settings: Manual = 9 o’clock / Speed = 9 / Width = noon / Regen. = 9 Not quite as full-bodied/chewy/magical as the original, but fairly close. Add delay to taste for some 17 Seconds/Faith-era Cure tones.
Tangent: Since I use the MXR flanger all the time, I’ve also considered getting PastFX’s Hot for Flanger pedal and letting the Eventide handle other sounds. Haven’t tried it yet, but all their pedals have gotten great reviews and I’m blown away by their New Division (EHX Clone Theory update). Outstanding customer service, too.
May 2, 2023 at 4:20 am #170833
Most of the images disappeared from posts when Eventide updated the forums. I used one of Brock’s presets above to try to replicate my M117 (old model) sound, although I wasn’t after the EVH stuff (and I’m honestly not that familiar with it, as I lean more toward the clove cigarettes, fog machines and pointy shoes than spandex and sneakers from that era. Big hair in either case though!) I haven’t been able to get the H9 / H90 to sound as substantial or “chewy” as the real deal, which has just has more churn/heft/body to the sound than the H9, which is more swirly than churny, if that makes any sense. I suspect than an eq with an emphasis on the low-mids would help in that regard. I lean heavily on the MXR so I continue to use the 117 or a (reissue) micro flanger live. I discovered that I’m really picky about flangers and have gone through a few to try and replicate the sound I like in the MXR, and everything has come up short, but the H9 comes closest. (see “tangent” below). I’ve attached the preset I edited here. I found that it is really helpful as you’re dialing it in to assign one of the parameters to the expression pedal and sweep through it as you’re playing to find where it sounds best. I also got fancy and put both the original MXR and the H9 in a boss LS-2 and switched back and forth. (I did a similar thing to try to replicate a CE-2. The fun starts when you get close and then hit the gas / engage light speed with the Eventide to take it somewhere else). Notes from when I first made it:
Attempt to knock the old, cranky MXR Flanger with a sketchy foot switch and volume drop off my board. Based on MXR settings: Manual = 9 o’clock / Speed = 9 / Width = noon / Regen. = 9 Not quite as full-bodied/chewy/magical as the original, but fairly close. Add delay to taste for some 17 Seconds/Faith-era Cure tones. https://www.eventideaudio.com/presets/?search=mxr+forest
Wow, thank you for the detailed reply. Yes it’s disappointing to read a post about the very setting you are seeking only to find the image of the settings has long since disappeared.
I’m happy with some of the pointy shoe stuff too, and will oscillate between that and my teen guitar hero EVH (a lot of great music from that decade). If you’re interested in a very quick sample of the Van Halen flanger sound, it’s in the intro to their song “Unchained”… The settings he used for that were apparently all knobs at 11:30. Except the Regen, which was at maximum. The original MXR has a very playful, alive character… Yes, chewy, as you describe it.
Thank you for the preset. Will certainly have a play around with it.
Yes, I’ve heard great things about the Hot For Flanger, and hoping to hear an actual side-by-side test with it, and an old “Reticon chip” MXR Flanger, doing the EVH sounds. Unfortunately the newer MXRs, even the striped EVH model simply don’t get the same sound as the original. If you do try the Hot For Flanger, please chime in here and leave a report or a link to a side-side video. Thank you again.
May 2, 2023 at 4:45 pm #170873
Great. I hope it’s helpful, or at least a good starting point.
Tangents:
The H9 (and H90) are pretty incredible. I’ve found it more productive to approach it from a functional perspective rather than trying to mimic a particular pedal, i.e., I want this part to be swirly/flangy/unstable rather than sound exactly what pedal XY does. (And, frankly, I’ve not been able to nail the exact sounds anyway). The possibilities are (almost) limitless, but that also means there are less (easy) happy accidents with the MXR’s four knobs.
Alternately, I’ve also come to terms that the H9/H90 can function as (almost) anything, but it may be more efficient to use dedicated pedals for some sounds. For example, I have a Diamond Compressor as an always-on pedal. I could probably get an H9 to serve that purpose, but then it wouldn’t be free for other stuff. The same goes for a Boss DC-2 dimension chorus. Brock did some amazing work to get the feel of it with an H90, but it’s just easier to have the Boss pedal do that work. In other words, it’s not an either-or choice.
