Trying to get the 2.0 beta for H9000
Home Forums Products Rackmount Trying to get the 2.0 beta for H9000
Viewing 8 reply threads
    • #116462
      joeydego
        Im online wireless, is your server down????? Getting a no releases message. Dongle is in place to go wireless and I’ve connected to my home network. Any ideas???
      • #157716
        joeydego
          Ended up installing off the supplied usb. Got to the screen on the H9000 to update and was on my home network. Anyway, kudos on the new emote. Looks great!
        • #157717
          zengomi
            Maybe my case also points to some issue.
            My H9000 could not make a wired connection to Eventide’s server even though my router’s software showed the H9000 to be connected. So I too downloaded the file and installed via USB. That went smoothly.
          • #157721
              Sorry for your updating issues. I don't believe we had any server issues yesterday, I was able to see the new firmware update using both an ethernet-from-router connection and using the Wi-FI dongle and I have been in contact with other H9k users who were able to see the update on their unit.
              This is the general issue with the H9k needing to connect to the internet to see firmware updates; every network configuration is different which makes troubleshooting difficult and that is the reason why the new update process will be done exclusively through Emote. In the future, you shouldn't have any issues seeing firmware updates since they will be done using Emote, so as long as your computer that is running Emote is connected to the internet you should be able to update.
              I'm glad that you were both able to update using the USB updater and we hope that in the future you won't run into issues like this anymore.
              Enjoy the 2.0 beta!
            • #157722
              zengomi
                Thank you for the explanation. Looking forward to the next firmware!
              • #157724
                Jago_Marris
                  Really like the update from a point of overview and adding scenes to the H9000R. But I prefer the simplicity and look feel of the Daw plug-in of 1.3. So I have upgraded to 2.0 and my editor is 2.0 but my AU Plugin is 1.3. And it all works fine. Im sure this may sound a bit odd to some. But I like the simplicity of the 1.3 plugin. If I want to go deeper then leave the daw and go to the main editor.
                • #157725
                  Jago_Marris
                    Sorry – posted in wrong thread.
                  • #157726
                    resynthesis
                      A bit fiddly at first but it all worked, and works.
                      Brilliant work on your part!
                    • #157728
                      joeydego
                        Updating thru Emote will be a godsend. Updates don’t happen that often but trying to get the H9000 online and finding the update never went too smooth for me. I’m hard wired to the computer.
