Home › Forums › Products › Stompboxes › Tuner as a preset
June 1, 2018 at 8:24 pm #114768
kingston
ParticipantIs it possible to activated the tuner on the H9 as preset?
It might be easier than rattling around cc messages, which I can’t make my H9/G2 to do. -
June 2, 2018 at 4:45 am #149375kingston wrote:Is it possible to activated the tuner on the H9 as preset? It might be easier than rattling around cc messages, which I can’t make my H9/G2 to do.
No. Tuner cannot be assigned as a preset. Besides MIDI CC, you can also assign a MIDI PC message, or use an aux switch to toggle the tuner.
June 2, 2018 at 6:55 am #149377
I use an external Aux switch to toggle the tuner easily as shown in this video: https://www.eventideaudio.com/community/videos/h9-quick-tips-tuner
With regards to using CC to toggle the tuner, did you assign a MIDI CC to the "toggle tuner" option under the MIDI CC Receive Map using H9 Control? You find it under the "Pedal" page > MIDI Settings > Assign MIDI CC Messages > Toggle Tuner. Assign it a controler number. Once that is set, you need to program your MIDI controller to send the CC change on the MIDI channel of the H9 in question whenever you press the controller's footswitch. Some MIDI controllers allow you to connect an external switch to it for this purpose, so that you're not wasting a preset button for engaging the tuner.
April 29, 2020 at 6:50 pm #154753
kjellace
Participanthi
i have a aux switch conected, but i have to tap it twice to engage the tuner. Do you know why? i have tried with two different aux pedals
Kjell
joecozzi wrote:I use an external Aux switch to toggle the tuner easily as shown in this video: https://www.eventideaudio.com/community/videos/h9-quick-tips-tuner
With regards to using CC to toggle the tuner, did you assign a MIDI CC to the “toggle tuner” option under the MIDI CC Receive Map using H9 Control? You find it under the “Pedal” page > MIDI Settings > Assign MIDI CC Messages > Toggle Tuner. Assign it a controler number. Once that is set, you need to program your MIDI controller to send the CC change on the MIDI channel of the H9 in question whenever you press the controller’s footswitch. Some MIDI controllers allow you to connect an external switch to it for this purpose, so that you’re not wasting a preset button for engaging the tuner.
October 4, 2018 at 7:38 pm #150247
mustafaicil
ParticipantI think I found a way. In the H9 app MIDI settings, there is a section to assign PC# commands to Enable Tuner and also assign other MIDI PC# mappings similar to AUX switch mappings. I could not try it yet since I do not have a MIDI controller to test it with.
January 15, 2019 at 4:17 pm #151010
knna
MemberHi, I use h9 control when I play live. When I change the preset I can see the settings. Would it be possible that when I use the tuner it appears on the screen? It would be a great help.
Thank you very much, Regards.
April 30, 2020 at 10:52 pm #154777
camn
ParticipantSide note, just to shitpost- Why on earth is the default not
PC0 = tuner.
PC1= Preset 1….
PC99= preset 99?
It took me forever to re-assign all those.
/shitpost
May 7, 2020 at 9:09 pm #154816
birthofahero
ParticipantHow is the tuner on the h9 compared to something super accurate like a turbo Tuner?
May 8, 2020 at 5:52 pm #154825
camn
ParticipantIt is sufficient.
August 20, 2020 at 1:03 am #155575
gas hed
ParticipantHi there folks – can someone point me in the direction of an auxilary switch for easy tuner access? What, where, cost? Thanks!
August 20, 2020 at 1:19 am #155576
camn
ParticipantAny n.o. momentary switch will work.
A lot of people use the Tesla Tap, but honestly anything.
Making your own out of parts costs, like, $10 tops.
August 20, 2020 at 1:22 am #155577
April 29, 2020 at 8:38 pm #154756kjellace wrote:
hi
Please check to see that the aux switch is not accidentally mapped to more than one device. If you use H9 Control, go to PEDAL>Aux Swith Mappings – Make sure that whatever is mapped to "Toggle Tuner" is not somewhere else, too.
PC0 = tuner.
PC1= Preset 1….
PC99= preset 99?
This is just because in developers' minds, 0 represents the first index in a list. Personally I admit this was a mistake that Eventide made. But hey, at least we made all MIDI messages assignable so you already fixed it.
May 7, 2020 at 11:58 pm #154817birthofahero wrote:How is the tuner on the h9 compared to something super accurate like a turbo Tuner?
I find it accurate and use it all the time. But maybe you wanna hear from some other users as well.
