June 15, 2016 at 10:13 am #113510
alienimplant
ParticipantIf I play my song, everything works fine. The minute I bounce (in real time), the meters freeze and the gates get stuck. I sometimes changes once or twice in a five-minute song, but essentially the plugin breaks during a bounce. I CAN’T FINISH MY MIXDOWN. 🙁
Logic 10.2.3, build 4369.35. Tverb 1.0.0
Help… please :s
June 15, 2016 at 3:11 pm #143590
Hi alienimplant-
We'll take a look into reproducing this issue here. In the meantime, when you say the meters freeze and gates get stuck, does this happen visually, or do the gates audibly stop working? What happens if you bounce with the plugin GUI closed?
Additionally, what version of OSX are you using?
Thanks,
Tom
June 15, 2016 at 4:19 pm #143591
alienimplant
ParticipantYes, visually and in behavior. Once or twice duing the bounce, it may switch behavior for a second. The gate position changes and the LEDs change position yet remain frozen again.
I’m on 10.11.5 (15F34)
June 15, 2016 at 4:54 pm #143592
alienimplant
ParticipantThe audio behavior is the same whether the plugin GUI is open or not.
June 15, 2016 at 5:10 pm #143593
alienimplant
ParticipantAs a reminder, this only happens during bounce (realtime) in Logic. Standard playback doesn’t exhibit the problem, so this didn’t become apparent until I was in the last stages of the project. I will not make my intended release date this week as a result. Please note that I cannot run an offline bounce for this project as there is an analog loop involved in the bounce process.
June 15, 2016 at 5:52 pm #143594
Ok, thanks for the addittional information. We haven't been able to reproduce here, but will continue to try. Do you have any automation written for the plug-in in this project? Does this issue also happen if you try a realtime bounce in another session?
I understand the need to do a realtime bounce. In the meantime, as a workaround, you could print the track(s) using Tverb (either with an offline bounce, or by routing to a new track and recording the output), and then do the realtime bounce.
June 15, 2016 at 6:28 pm #143595
We've been able to reproduce here, I will look into a fix and get back to you ASAP.
June 15, 2016 at 6:59 pm #143596
alienimplant
ParticipantThat is wonderful news!
June 16, 2016 at 5:25 pm #143599
Hi, we've found a fix, and hope to have new installers next week.
June 16, 2016 at 5:43 pm #143600
alienimplant
ParticipantCan I at least get a copy of the new AU? I’m behind on my deadline. I don’t need an installer. Consider me a beta tester for it.
June 16, 2016 at 10:42 pm #143601
Sure, email support@eventide.com mentioning Tverb and getting a fix, and we'll get it to you.
