Home › Forums › Products › Stompboxes › Two H9 in Windows Midi devices as “H9 Pedal”
May 30, 2016 at 1:43 pm #113470
ReverendLove
ParticipantIn device manager or the list of midi devices in software (cubase, Sound Forge, Midi-OX…) two pedals have the same name. The mentioned programs select the pedal by coincidence. On reopen of a saved project the program opens the correct device with a chance of 1:1.
That bugs me alot. Is there a way out of this kerfufle? -
May 30, 2016 at 1:45 pm #143462
gkellum
ParticipantReverendLove wrote:In device manager or the list of midi devices in software (cubase, Sound Forge, Midi-OX…) two pedals have the same name.What version of Windows do you have installed? I'm not the best person to respond to Windows specific questions, but if I remember correctly, Windows XP has a problem with reading the names of USB Audio devices, but in later Windows operating systems the H9 appears with its serial number as its name.
May 30, 2016 at 4:40 pm #143466
ReverendLove
ParticipantI have Windows 10 prof. 64bit with the recent updates.
The H9 Control in Windows recognizes the pedals correctly under the given names H9-Max and H9-Core but neither the device manager nor applications which use MIDI do. They give both the same name “H9 Pedal”. And while H9 Control recognizes them via USB I wonder why the device manager doesn’t.
If I rename them according to H9 Control they are set back after restart both to “H9 Pedal” . Cubase for example grabs the first one initialized. Depending on the order of other USB devices and their activity it is unpredictable which one will be used. Because I automate them in my DAW I need to trust in the order or an exact naming of the devices.
June 1, 2016 at 5:27 pm #143475
H9Control knows about these pedals, so it can tell the difference. DeviceManager and other non-Eventide applications do not. Sorry.
June 1, 2016 at 8:08 pm #143476
ReverendLove
ParticipantBad. This is what I suspected.
But thanks for your answer anyway.
Probably you’ll find a way to solve this.
