Two Mono Sources + FX Loop on H90
Home › Forums › Products › Stompboxes › Two Mono Sources + FX Loop on H90
    • #183186
      amc8
        Hi All,
        I am wondering if I can achieve this setup.
        Ideally I would like to plug my guitar, and one (mono) keyboard into the h90, while also having an external mono fx loop.
        Could I plug guitar into input 1, synth into input 2, and use I/O 3 and 4 to run my external mono fx chain?
        Alex
      • #183187
        amc8
          Thinking now I could run the mono fx chain on insert 2 (in 4 – out 4) .
          Guitar into in 1.
          Keys into in 3 as a return.
          • #183193
              Yes, this would be the correct way to do it.
              If you have your guitar on input 1 and your synth on input 2, the H90 will think that is a stereo input and you will most likely have undesirable results with how the effects processing works.
              Guitar on input 1 and synth on input 3 will give you the correct mono inputs, use routing mode to determine where the synth (insert 1) is in the signal path.
              Let me know if you need any help with this.
          • #183228
            amc8
              Amazing thank you!
