two questions
Home Forums Products Rackmount two questions
Viewing 3 reply threads
    • #106347
      lionelred
      Hi there
      I am still trying to figure out this xlr to unbalanced issue.
      I think i have the right cables. XLR to a 1/4 Jack that only has one ring
      Is this the correct cables or do i need something specific because its still seems noisy to me.
      Also I have a MacPro with the digital connectors I wanted to get the right cabling (tosLink)?
      Am i able to transmit 96k via this as i have a apogee duet which doesn't have digital.
    • #118857
      If you want to connect from an XLR to a mono jack (tip and sleeve only) both the screen (pin 1) and one of the other pins (2 or 3) must be connected to the sleeve of the jack. Otherwise you WILL get noise.
      I assume your MacPro tosLink connectors are for stereo S/PDIF. If so, these should work at 96K. Eclipse does not support an ADAT format (4 or 8 channels) at 96K.
    • #118863
      lionelred
      I thought it was advised to use these inputs?
       I am using outboard gear/drum machines etc
      would it be fine to use the 1/4 jack to 1/4 jack?
    • #129988
      Not sure what you mean.
       I am using outboard gear/drum machines etc would it be fine to use the 1/4 jack to 1/4 jack?
      If they have 1/4" jacks you could certainly use them. Note that you have a greater chance of noise and ground loops when going unbalanced.
