June 10, 2014 at 11:52 pm #111687
stanton5150
MemberI downloaded and licensed the Ultra Channel Free plug in for Mac today seemingly with no issues, but when I open up Pro Tools 10 I can't find it anywhere in the plug in drop down menu. Am I looking in the wrong place? Is there another step in the licensing process I missed? It is listed as "active" to both my iLok and computer in the iLok License Manager app.
Any input helps, thanks!
-Andrew
June 11, 2014 at 3:54 am #126084
NoOne
ParticipantSame here with Ableton Live 9. It works on wavelab LE 7 but it doesn't even appear on live's plug in browser.
June 11, 2014 at 4:59 am #126085
NYC Composer
MemberExact same problem. Mac 10.68, Cubase 6. The plug in is installed and activated on my iLok, but doesn't show in my list of available inserts.
June 11, 2014 at 1:52 pm #126087
Hi stanton5150.
Which version of Pro Tools are you using. UltraChannel is only compatible with PT10.3.6 and higher.
Dan
June 11, 2014 at 1:56 pm #126088
Hi NoOne,
Are you using Live on Windows or Mac? If Windows, are you sure that you have live 9 (32 or 64 bit) pointing to the same folder the VST plug-in was installed? (c:Program FilesCommon FilesSteinbergVST2 for 64 bit and c:Program Files (x86)Common FilesSteinbergVST2 for 32 bit).
I use it in Live 9 all the time, so I'm certain it works.
Dan
June 11, 2014 at 1:58 pm #126089
Hi NYC Composer,
Some Cubase users have had to rescan their plug-in folders. You may have to double check to make sure it's installed to the right folder, then rescan the folder in Cubase. I'm sure it's working in Cubase as well.
Dan
June 11, 2014 at 2:10 pm #136799
stephenvit
MemberI got the email but then told the specified access code is invalid.
June 11, 2014 at 3:25 pm #136800
stephenvit
Memberactually, problem resolved. Got a quick reply from Eventide but also found that I couldn't authorize in Chrome but could in Firefox. No complaints. Happy for the gift
June 11, 2014 at 4:40 pm #136801
NoOne
ParticipantHi DGillespie,
I am using live 9 32 bit on windows xp, the folder is the same folder I have all my VST plug-ins .
I rescaned the folder few times, rebooted my pc but still ultra channel doesn't even appear.
Any ideas?
Thanks for your help.
June 11, 2014 at 4:46 pm #136802
Hi Stephen,
There were some problems with some of the access codes initially, but they should have all been fixed yesterday morning. Did you try copying and pasting the access code directly from the email into the form?
June 11, 2014 at 5:24 pm #136803
violetpow
ParticipantIn OSX 10.9.3 and Live 9.1.2 64 Bit no issues at all for the installation. But the only issues i find is, that the delay does not sync to the host (sys tempo on) and the Omnipressor distorted if the attack is 0.1 ms.
June 11, 2014 at 5:56 pm #136806
Hi NoOne,
Maybe try manually removing the plug-in and installing again, but this time check just the 32 bit installer?
Also, do you have iLok License Manager installed, and do you see the license in iLok License Manager?
Thanks,
Dan
June 11, 2014 at 6:04 pm #136807
Hi Violet,
Do you have Session Tempo and Tempo Enabled both on? And have you tried pressing play?
The Omnipressor will add distortion and harmonics at very fast attack and release times, this is one of it's charms. (If you think about it, an attack time of 0.1 mS is like saying an attack time of 10 kHz)
Dan
June 11, 2014 at 9:08 pm #136808
NYC Composer
MemberHi Dan- that worked, thank you, although just fyi to other Cubase 6 users, the scan was slow and ssomewhat weird- ended up finding old versions of plug ins it didn't want to authorize(like Kontkat 3!) and crashed a few times, which never happens to me. Caveat Emptor.
June 13, 2014 at 1:32 am #136830
NoOne
ParticipantWell, deleting the .dll and installing again worked.
Ultrachannel is a lovely plug-in so far.
Thanks.
June 14, 2014 at 4:30 pm #126129
diogocme
ParticipantWorks on Cubase 7.5 – 64bit. No problems there, but on PT 10.3.7 I'm getting an authorization error. The license is my (usb) ilok – 100% sure about that, but PT doesn't seem to get it…anyone else had this?
Cheers
June 14, 2014 at 6:55 pm #126133
Hi Andrew,
Are you using Pro Tools 10.3.6 or higher? UltraChannel is not compatible with Pro Tools 10.3.5 or below.
Dan
June 14, 2014 at 6:55 pm #126134
Hi diogocme,
What is the exact error you are seeing?
Dan
June 14, 2014 at 7:27 pm #136836
diogocme
ParticipantI'm getting this:
PT 10.3.7 @ Win7
June 14, 2014 at 7:44 pm #136837
diogocme
ParticipantDouble post – please delete this.
