Ultrachannel (Audio Units) not working with Bias Peak 7.0 (OSX)
Home Forums Products Plug-Ins Ultrachannel (Audio Units) not working with Bias Peak 7.0 (OSX)
Viewing 3 reply threads
    • #111752
      dowda
      Ultrachannel (Audio  Units) seems to  not work with in Bias Peak 7.0
      (OSX version Snow Leopard)
      The GUI is  rendered correctly  ,  but the meters do not show any activity,
      and no audio is passes through the plugin
      Other Eventide plugins work fine.
      Ultrachannel works fine inside of Logic 9.
      Regards,
      David Gilden / Ft. Worth Tx
    • #126254
      tlongabaugh
      Hi David-
      Thank you for the heads up, we will try to look into the issue. Did you encounter the same problem for the VST version as well?
      Unfortunately Bias the company hasn't been around since 2012, so it is hard to support/test for Peak.
      Tom
    • #126256
      DGillespie
      Yes,
      Unfortunately Bias is out of business and we won't be able to support their product.
      I'm Sorry,
      Dan
    • #126262
      dowda
      Never  tried the VST version — but will give it a try.
      Thx
      DG
