Ultrachannel causes immediate out of memory issues in PT HD Native
Home Forums Products Plug-Ins Ultrachannel causes immediate out of memory issues in PT HD Native
Viewing 7 reply threads
    • #111689
      mrgrimm01
      OSX 10.8.5
      PT 10.3.9 HD Native
      Omni Interface
      20 gigs of ram
      Anyone see this using PT?
    • #126092
      DGillespie
      Hi mrgrimm01,
      We're not seeing this problem at all over here.  I'd be curious to see if anyone else was having this problem as well.  Have you tried an empty session?
      Dan
    • #126093
      mrgrimm01
      May have been a premature post – so far it seems to be specific to that one session.  It instantiates in a clean session as well as in another preexisting session.
      100% repro with the original session I've used it on.  Strange…
    • #136809
      DGillespie
      Thanks mrgrimm,
      You may actually be out of memory in that session.  What happens if you remove some and try it again?
      Thanks,
      Dan
    • #136815
      mrgrimm01
      There doesn't seem to be a way to attach two pics, so I'll post twice, but w/o ultra channel I'm at around 17% cpu usage.  With Ultrachannel I'm constantly in the red, although the numeric percentage doesn't seem to change significantly, but that may just be a gui thing.
    • #136816
      mrgrimm01
      second post with pic with ultrachannel instantiated.  Even if I disable ALL other plug ins in that particular session I'm still constantly overloading.
    • #136819
      DGillespie
      Hi mrgrimm,
      Are your issues related to memory usage or CPU usage?
      We've heard some complaints of abnormally high CPU usage from some people – generally those with older machines, though we haven't had a chance to look into it further.
      Dan
    • #136822
      mrgrimm01
      Apologies – CPU usage.  Pic attached.
