Ultrachannel Delay Sync not working
Home › Forums › Products › Plug-Ins › Ultrachannel Delay Sync not working
Viewing 3 reply threads
    • #111814
      4edawg
        Hi, saw the previous poster also had an issue with Ultrachannel delay sync.  I'm on Protools though.
        So even when the Sys Tempo button is lit orange (on?), the tempo doesn't follow the session tempo, needs to be entered manually.
        However even when the tempo is correctly set, the Delay amounts cannot be adjusted via the knobs.  They're stuck on 250ms and can't be moved, unless Sys Tempo is turned off.
        Forrester
        Protools 11.1.3 HDX2 MacOSX10.9.3
      • #126412
        tlongabaugh
          Hi Forrester-
          Thanks for bringing this to our attention. Sys Tempo is indeed on when it is lit orange. I haven't been able to reproduce the issue, but I will look into it.
          Thanks,
          Tom
        • #126413
          4edawg
            Hi Tom
            Yes its intermittent, as i'm successfully using it now.  Will investigate further and try to find the catalyst.
          • #137093
            tlongabaugh
              Forrester-
              Thanks, that would be much appreciated. I've been doing some testing and have had intermittent troubles as well; we are looking into getting this sorted out.
              Thanks,
              Tom
