June 16, 2014 at 2:41 am #111710
tamprecision
Participanthi there eventide gurus – any help with this MASSIVELY appreciated
im trying to install utrachannel, i have my ilok all set and license downloaded fine
when i try to validate in AU manager i get the following:
AU Validation Tool
Version: 1.2.1b3
Copyright 2003-2007, Apple, Inc. All Rights Reserved.
Specify -h (-help) for command options
VALIDATING AUDIO UNIT: 'aufx' - 'UlCh' - 'Tide'
Manufacturer String: Eventide
AudioUnit name: UltraChannel
Component Info: Ultra Channel
Component Version: 2.0.5 (0x20005)
Component's Bundle Version: 2.0.5
* * PASS
TESTING OPEN TIMES:
COLD:
2014-06-16 03:35:05.897 auvaltool[1069:80f] Error loading /Library/Audio/Plug-Ins/Components/UltraChannel.component/Contents/MacOS/UltraChannel: dlopen(/Library/Audio/Plug-Ins/Components/UltraChannel.component/Contents/MacOS/UltraChannel, 262): no suitable image found. Did find:
/Library/Audio/Plug-Ins/Components/UltraChannel.component/Contents/MacOS/UltraChannel: unknown required load command 0x80000022
FATAL ERROR: OpenAComponent: result: -50,0xFFFFFFCE
validation result: couldn't be opened
updating properties of AU UltraChannel by Eventide...FAILED!
June 17, 2014 at 9:45 pm #126158
Hi Tamprecision,
It looks to me like you might have a problem with the license. If you go into iLok License Manager, do you see the UltraChannel Native license as active in your computer or on you iLok?
Thanks,
Dan -
June 18, 2014 at 1:45 am #126159
tamprecision
Participanthey dan i looked at the license manager and it was active on the ilok key, I have an ilok key
i tried transferring it to the computer but got the same result
im running on mac osx 10.5.8 – could this be the problem
thanks SO MUCH for your help Dan, really really appreciate it
heres the message i got when the license was active on the computer
AU Validation Tool
Version: 1.2.1b3
VALIDATING AUDIO UNIT: 'aufx' – 'UlCh' – 'Tide'
* * PASS
TESTING OPEN TIMES:
COLD:
2014-06-18 02:39:10.373 auvaltool[196:80f] Error loading /Library/Audio/Plug-Ins/Components/UltraChannel.component/Contents/MacOS/UltraChannel: dlopen(/Library/Audio/Plug-Ins/Components/UltraChannel.component/Contents/MacOS/UltraChannel, 262): no suitable image found. Did find:
updating properties of AU UltraChannel by Eventide…FAILED!
June 22, 2014 at 2:12 pm #136860
Hi tamprecision,
OS 10.5.8 is almost certainly the problem. Mac changes things fairly quickly and often makes it so that if we want our software to be compatible with 10.9, we have to lose compatibility with some of the older OSs. I believe we're still compatible with 10.6, but not 10.5.
Sorry,
Dan
