Ultrachannel Vs H3000 micropitch
Home Forums Products Plug-Ins Ultrachannel Vs H3000 micropitch
    • #166650
      Sebastian79
        Hello, I noticed that these plugins micropitch sounds a bit different from each other. Are they different? If not, what are the equivalent controls on the h3000 as the ultrachannel?
        Thanks
      • #166737
        tlongabaugh
          Hey Sebastian, they are indeed slightly different – the underlying pitch shifting algorithm differs between the two. Additionally, the UltraChannel controls map to the following, which you could set up in Factory to get close in sound:
          • Size controls shift amount – left channel shifts up, right channel shifts down
          • Depth controls delay time (slightly asymmetrically, left channel can be delayed slightly more than right channel)
          • Width controls the mix between left / right voices
          Hope that helps!
