November 8, 2015 at 1:26 pm #113007steinholtzMemberHi,after updating Ultrareverb all my Ableton projects using Ultrareverb are crashing Ableton. I have been in contact with abelton and from the crash reports they can see that the crash is happening inside of Ultrareverb. This is of course catastrophic not being able to open any old projects!I’m using Ableton 9.5 64-bit and Ultrareverb 2.0.17 running on Mac Pro 4.1 OSX 10.9.5. The crash also happened with Ultrareverb the version 2.0.11. Not sure what version of Ultrareverb I was runing before that, but It was stable.Isnt there a way for me to get the older and stable version of Ultrareverb?Kr,Andreas
November 9, 2015 at 12:22 am #141475DaveBenyakParticipant
Andreas,
Check my posting of November 8, 2015. and try that based on where Ableton wants to install its plugins. It may need for you to manually created the Eventide folder.
Regrads,
DaveBenyak
November 9, 2015 at 4:35 pm #141480
Hi Andreas-
Sorry to hear that you're having problems with UltraReverb in Ableton.
-Are you using the AU or VST version of UltraReverb?
-What directory is the plug-in located in?
-Can you send us/post here the crash report so we can see what is happening?
We can get you an older version of UltraReverb in the meantime. Send an email to support@eventide.com mentioning your issue and my name, and I can send you an older version.
Best,
Tom
November 17, 2015 at 12:40 pm #141561steinholtzMemberTLongabaugh wrote:
Hi Andreas-
Sorry to hear that you’re having problems with UltraReverb in Ableton.
Best,
Tom
Hi Tom,
i’ve reasearched further and it seem that 2.0.17 IS stable in Ableton 9.5. However 2.0.11 did seems to throw an error in Ableton but so did Max For Live, and the crash that I got after updating Ultrareverb to 2.0.17 came from Max For Live and not Ultrareverb, so all is good.
Thanks for you help and sorry for the alarm!
Br,
Andreas
November 17, 2015 at 3:32 pm #141562Steinholtz wrote:
Hi Tom,
i've reasearched further and it seem that 2.0.17 IS stable in Ableton 9.5. However 2.0.11 did seems to throw an error in Ableton but so did Max For Live, and the crash that I got after updating Ultrareverb to 2.0.17 came from Max For Live and not Ultrareverb, so all is good.
Br,
Andreas
Glad to hear you got it working, Andreas!
November 16, 2015 at 11:48 pm #1415605meohdMember
I am also having all sorts of issues with the VST demo of Anthology X inside of Ableton 9.5.
I see above someone mentioning the folder structure being a cause. But what can I do to fix that?
ben
ben
Hi Ben-
Could you let us know what issues you are running into, specifically? Also, what version of Anthology X are you demoing, and what OS are you running?
We had reports of VST problems on Windows 7 which were fixed in the latest build of AX, though I don't know if Windows 7 is your OS. Make sure you are using the latest version of AX, however (1.0.4): https://www.eventideaudio.com/products/plugins/multi-effect/anthology-x
Best,
Tom
