Home › Forums › Products › Plug-Ins › UltraReverb and UltraChannel Plugin Windows dont close in Ableton 9 / Yosemite
December 11, 2014 at 11:22 pm #112143doubledayMember
Hi all
I just got a shiny new Retina iMac running Yosemite and found that neither UltraReverb nor UltraChannel seem to be compatible with Ableton 9.
The Plugins open and work fine but when you try to close the plugin window it just destroys the plugin ui but the window would not close. Trying to edit opens a new window and even when the plugin is removed from the projects the windows will not go away.
Quick Demo:
https://dl.dropboxusercontent.com/u/5096376/UltraReverb.mov
Is this a known issue?
Any workaround and eta for a fix?
Cheers,
Daniel
December 15, 2014 at 10:47 am #127136doubledayMember
Found the answer myself.
Seems that eventide is using the and old version of JUCE and the 32bit versions of the plugin have drawing problems in Yosemite. So right now the only solution is to switch to ableton 64bit.
January 5, 2015 at 3:28 pm #127288
Ah Doubleday,
Thanks for the heads up. I'll take a look into this with the 32 bit version, and, if needed pull the latest JUCE.
Thanks,
Dan
July 7, 2015 at 3:32 pm #139606
Hi doubleday-
We have a fix for the issue, which should be included in future releases.
Thanks,
Tom
August 19, 2015 at 2:24 pm #140205maesenMember
hi tom
any news on this subject?
I’ve UltraChannel 2.0.21 on OSX Yosemite, Ableton Live 9.2.1. 32Bit installed and still experiencing this bug.
best, marcel
August 21, 2015 at 1:45 am #140223
Hi Marcel,
I just built these tonight. I'll give them the once over tomorrow and we should be able to post them Monday.
Sorry for the wait,
Dan
September 4, 2015 at 11:08 am #140416maesenMember
Hi Dan
Any plan on release date? Seems v .21 is still the latest availabe on your website.
Best,
Marcel
September 8, 2015 at 10:49 pm #140473
Sorry Maesen,
We ran into another issue which kept me from releasing it last week.
I just build the releases and I'm going to check them out. They should be up by Thursday at the latest.
Dan
September 11, 2015 at 6:25 pm #140509
Hi All-
The newest release is now posted on the site, which should solve the issue.
-Tom
September 13, 2015 at 4:27 pm #140533maesenMember
thanks alot eventide! problem fixed! 🙂
Great to hear!
