Ultrareverb – improving usability
Home Forums Products Plug-Ins Ultrareverb – improving usability
    • #112057
      4edawg
      Hey Eventide folks.  Ultraverb is one awesome plug.
      Would be great to get some key commands working, so that its just that little bit easier to use, mostly with regards to the stereo delay function.
      Shift – click to control both left and right values at the same time.  Also, if I want a slightly stereo delay, I have to go back to Tempo sync "off", and adjust in MS, however, if I wanted to change one side to a different synced value, it then resets the side I set in MS to the nearest Note value.  Not sure how you get around this, but i'm sure someone smart there will work it out.
      Thanks for listening.
      Forrester
    • #126987
      DGillespie
      Hi Forrester,
      I can add these as feature requests for a new version.
      Dan
