UltraReverb Not Found in Logic 9
Home Forums Products Plug-Ins UltraReverb Not Found in Logic 9
    • #112050
      jamesckoch
      I emailed the support address a few days ago but have yet to hear back.
      I followed the steps (as far as I can tell) to activate my copy of UltraReverb–the iLok License Manager software shows 1 activation on my machine–and Logic 9 is not recognizing the plug-in.  Below is a copy/paste of the message I get when I attempt to 'Reset & Rescan' in the Audio Units Manager.
      It looks like below it says "no suitable image found," I'm not sure how to resolve that.  I did download and try to use the installer.
      Please let me know what I can do to get up and running, and if you need more info from my end.
      validating Audio Unit UltraReverb by Eventide:
               AU Validation Tool
               Version: 1.2.1b3
                Copyright 2003-2007, Apple, Inc. All Rights Reserved.
               Specify -h (-help) for command options
      VALIDATING AUDIO UNIT: 'aufx' – 'Revb' – 'Tide'
      Manufacturer String: Eventide
      AudioUnit name: UltraReverb
      Component Info: UltraReverb
      Component Version: 32.0.4 (0x200004)
      Component's Bundle Version: 2.0.4
      * * PASS
      TESTING OPEN TIMES:
      COLD:
      2014-10-28 22:57:18.561 auvaltool[10060:80f] Error loading /Library/Audio/Plug-Ins/Components/UltraReverb.component/Contents/MacOS/UltraReverb:  dlopen(/Library/Audio/Plug-Ins/Components/UltraReverb.component/Contents/MacOS/UltraReverb, 262): no suitable image found.  Did find:
      /Library/Audio/Plug-Ins/Components/UltraReverb.component/Contents/MacOS/UltraReverb: unknown required load command 0x80000022
      FATAL ERROR: OpenAComponent: result: -50,0xFFFFFFCE
      validation result: couldn't be opened
    • #126992
      DGillespie
      Hi James,
      Can you try removing the binary and re-installing?  It looks like something might have gotten corrupted with that binary.  If this doesn't work please contact support@eventide.com and we'll try to dig deeper.
      Thanks,
      Dan
