Ultratap 2
Home › Forums › Products › Rackmount › Ultratap 2
Viewing 3 reply threads
    • #107950
      lionelred
        Hi There
         Is there any way of reducing the clicking sounds when you reduce the tap amount on this effect?
      • #122302
          Assuming you mean changing the number of taps, the answer would be no. Changing the number of taps is a very major change to the effect and is unlikely to be silent – it's not something you usually do while playing.
        • #122303
          lionelred
            Can i get around this on a H8000FW?
          • #133538
              Probably not – it's the same issue. Major changes are not usually silent.
