Ultratap firmware – what’s in it?
Home Forums Products Stompboxes Ultratap firmware – what’s in it?
    • #187151
      doodoomatomato
      Howdy. I just purchased a used Ultratap and hooked it up to EDM and it bumped up the firmware significantly, from 1.x something to the latest 2.x.
      I looked for release notes and didn’t find any. Does this update (or prior updates) add or change any features that I might want to know about?
      Maybe I’ll throw in a feature request: it’d be cool if the delay taps could be randomly scattered around the stereo field instead of ping-ponging as they do now. Or if you could adjust the stereo width. Although it doesn’t seem excessively hard-panned at present.
    • #187172
      The latest firmware for UltraTap allows you to use H90 Control instead of EDM.
      This is a big improvement for the software editor app as it allows bidirectional control of the parameter adjustments.
      You can download H90 Control here: https://www.eventideaudio.com/downloads/?product=H90+Control
      Thanks for your feature request. I’m not sure if we’d be able to add a stereo width adjustment on the dot9 version of UltraTap due to the limited amount of parameters, but the H90 version of the algorithm does feature a Width control.
