Ultratap iOS and Audiobus
Home Forums Products Plug-Ins Ultratap iOS and Audiobus
    • #115570
      Joe Capricorn
      I’ve just bought Ultratap for iOS, awesome, and I’m trying to use it with Audiobus but in the Audiobus app UltraTap doesn’t display.
      What’s the problem?
      Thank you in advance for your support
      Best Regards
      Joe
    • #152981
      tlongabaugh
      Hey Joe-
      UltraTap should be compatible in the "Audio Units" tab of AudioBus, when you go to add an effect. Does it show up there?
      Also make sure you have the latest version of UltraTap updated on your iDevice.
      -Tom
    • #152982
      Joe Capricorn
      Hello Tom,
      I use Audiobus 2 App and the problem is that Eventide UltraTap doesn’t display in the Effect tab, neither the other ones as you can see from the attached screenshot.
      The UltraTap version is that one of two days ago.
      Regards
      Joe
      tlongabaugh wrote:
      Hey Joe-
      -Tom
    • #152985
      tlongabaugh
      Hi Joe-
      Ah, I suspect Audiobus 2 only supports products using the Audiobus API, and not IAA or AUv3. The Eventide apps only support IAA and AUv3.
      -Tom
