Home › Forums › Products › Stompboxes › UltraTAP – IOS and H9 Width
July 23, 2019 at 12:03 pm #115437cliveluisParticipant
I was trying to copying H9 ultratap presets to IOS AUv3 ( i believe preset sharing is desktop and IOS only)
However I found an extra Width knob on IOS version
What is the “neutral/fixed” postion of Width postion on H9? is it 12 Clock?
July 23, 2019 at 6:06 pm #152388
Hey-
The "neutral" position of the Width knob is fully clockwise (value of 100). This corresponds to the behavior on the H9, where the Taps alternate being panned hard left/right (provided you are using stereo out).
Btw, you shouldn't need to do any additional editing of the preset files, when going between H9 and AUv3/Desktop. Presets saved on H9 will load in the AUv3/Desktop plugin with a Width of 100.
-Tom
July 23, 2019 at 7:27 pm #152391cliveluisParticipant
Really.. I tried saving single preset from h9 in IOS files app .. did not work for me
July 23, 2019 at 9:28 pm #152392
Sorry, I should have been more clear. What I meant is that you don't need to do any editing of the preset files when going between the two – Width will take care of itself.
As far as exporting: Presets saved in H9 Control will not automatically appear in the iOS Files App. You'll have to export them as you normally do from within the H9 Control app. When you later import them into the Files app and place them in the "UltraTap" folder, they will appear in the UltraTap iOS app.
July 24, 2019 at 5:51 am #152393cliveluisParticipanttlongabaugh wrote:
Sorry, I should have been more clear. What I meant is that you don’t need to do any editing of the preset files when going between the two – Width will take care of itself.
As far as exporting: Presets saved in H9 Control will not automatically appear in the iOS Files App. You’ll have to export them as you normally do from within the H9 Control app. When you later import them into the Files app and place them in the “UltraTap” folder, they will appear in the UltraTap iOS app.
Iam aware of files app transfer, but did not show up
See steps
I emailed A preset to myself from H9 control
saved preset to files app ( location : on my iphone)
Opened blackhole app. It Did not show up in user presets ( in which folder is it supposed to show up)?
I purchased both blackhole and Ultratap
Device used for testing Iphone 8 plus
See steps
Ah, I think I know what's happening here – the presets need to be placed in On My iPhone -> Blackhole.
The iOS Files App hides empty folders by default. When Blackhole is installed it creates a folder On My iPhone -> Blackhole, but this is automaticaly hidden in the Files App, because it is empty. To circumvent this, for the moment you'll need to save a User Preset from the Blackhole app (Standalone version, not AUv3). That will cause the On My iPhone -> Blackhole folder to show up – once it does, place your H9 presets there. Then, relaunch Blackhole Standalone, and your presets should appear.
We will look into a way to force the folder appear without saving a User Preset first.
Let me know if you still have problems, or I've misinterpreted your issue.
-Tom
July 24, 2019 at 8:14 pm #152401cliveluisParticipanttlongabaugh wrote:cliveluis wrote:tlongabaugh wrote:
See steps
-Tom
I had no such issue about folder being hidden .. I could see it
I was probably expecting a user presets folder
Tried your workaround but the preset I imported does not show up
July 24, 2019 at 8:17 pm #152402cliveluisParticipant
Hi
I could not send screenshots .. sent by email
July 24, 2019 at 9:06 pm #152403
Thanks – got the screenshots. Can you attach the preset you are trying to import, or send it over email?
July 24, 2019 at 9:39 pm #152405
My apologies – I just spoke to my colleague who works on H9 Control about this, and figured out what is going on:
-The Blackhole App reads .tide presets only.
-H9 Control was updated a while back to export single presets as .tide files instead of .h9z files, but it looks like this change only made it into the desktop version. Since you're exporting on the iOS version, the extension is still .h9z, and thus the Blackhole app isn't reading it.
As a workaround, please save any presets you'd like to import into the Blackhole app using the desktop version of H9 control. I've attached the LAMBOFGOD preset as a .tide file, please let me know if you can import it correctly.
We will release a fix for H9 Control soon. Sorry for the hassle.
July 25, 2019 at 5:23 am #152407cliveluisParticipant
Strange ways of IOS
I could not open/download this on phone .. it was opening a bunch numbersHowever from laptop I could download and emailed it back to me on my phone …and voila it’s working via files app transfer
August 1, 2019 at 8:14 pm #152439WallowerMember
Would it ever be possible/likely to update H9 Control app to export presets/lists/backups to iOS Files, Dropbox, etc? And/or, export in such a way to streamlining sharing between the Control app and AUv3 apps? Then could one almost use the AUv3 apps to tweak H9 presets with a pre-recorded track while away from the H9?
Currently, you can export presets/lists by emailing them in H9 Control. It would be great if users can export to the Files app and import from there though. We will look into that.
September 29, 2019 at 4:11 pm #152803cliveluis wrote:
Please note after latest update this feature is still not functional ! H9 control exports presets as . Tide .. into files app .. but they do not show up under user presets
You would need to export the .tide presets into the Blackhole folder in the Files app
I just shared one of my Blackhole presets from H9 Control to the Blackhole folder in the Files app. And when I opened the Blackhole app I saw my preset there. Did you close and reopen your Blackhole app?
