- This topic has 8 replies, 2 voices, and was last updated 3 years, 1 month ago by
luedmo.
March 1, 2022 at 5:22 am #162531
Ultratap Ultraswell
…on the h9 works great – with MIX at 100% and using the CHOP set at Swell 5Same Algo, same Preset on the h9000: the CHOP button setting “Swell 0” through “Swell 9” and “Trigger 1” to “Trigger 3” allow no sound through. Can only think the sensitivity settings might need a tweak at some point? All the other CHOP settings work as per normal (I think).
Thanks
:L -
March 1, 2022 at 11:52 am #162597
I just tried out the “Ultraswell” preset on the H9000 and I am not experiencing these issues. I think you may not be driving the algorithm hard enough trigger the swell/gate and hear the effect, can you try bumping up the input gain a bit and seeing if that works for you?
March 2, 2022 at 6:38 am #162628
Thanks,
I also thought that sensitivity might be the issue, it’s weird because the h9 Ultraswell works just fine as well as all the other Algos
fwiw – my guitar is going into a SynergyAmps SYN2 with Balanced outputs > h9000 analogue XLR inputs. I also have it all hooked up over ADAT with a MH2882+dsp box – which works great. My db25 analogue connection needs some TLC, so far not used)
I will test it and get back to you – hopefully we find the solution which can help other users
:Lps: while we are on the subject of sensitivity doe you have a good URL about the ADSR and Envelope settings on the “SHAPE” knob for say Chorus?
March 2, 2022 at 8:57 am #162630
thanks tbskoglund!
It works with more boost (like +7dB approx)
I’ll check all my gain structure, but as I am already hitting -6dB on that VU I’m already quite near the top
Also, to mentiuonb that my PitchFuzz comes before the Ultraswell (with a -5dB cut on its i/o settings) then Ultraswell again doesn’t react
Going back to my other post (about saving i/o settings inside the Algo preset regardless of Bypass Tails)… this still has me wondering.
If I find out anything more out I’ll let you knowAttachments:
March 2, 2022 at 9:39 am #162632
Glad to hear that works for you, I need to boost the input as well (or play very hard). You can just boost the input of the UltraTap algorithm itself, not the FX Chain’s input gain. Or, in the above example you could try boosting the output of the Chorus algorithm.
March 2, 2022 at 12:56 pm #162641
Thanks
You mean adjusting this dial?
:L -
March 2, 2022 at 1:01 pm #162642
…and with the image
“You can just boost the input of the UltraTap algorithm…”So we have to adjust the i/o of IN GAIN and OUT GAIN and use MAP to return to 0dB when the BYPASS is switched in.
There must be a way to do this without all that MAPPING…
(in hope):L
March 2, 2022 at 1:52 pm #162645
Yes, I am referring to the IN GAIN parameter. It’s up to you if you want to always map the gain to return to 0 when bypassed with your configuration. When I am using this, the gain increase is not making that noticeable of a difference. If the higher signal is an issue for you, you can decrease the output of your FX Chain. Or you can set UltraTap’s IN GAIN to +6 and OUT GAIN to -6, and this should balance things out without additional mapping.
March 3, 2022 at 12:19 pm #162673
Thanks for the help! 🙂
This should work nicely, and I see that the i/o settings seem to be saved, even though a BYPASS does not bypass the i/o
Best
:L
