Unable to see plugin in Cakewalk SONAR Platinum
Home Forums Products Plug-Ins Unable to see plugin in Cakewalk SONAR Platinum
Viewing 4 reply threads
    • #113440
      rgturner
        I just installed UltraReverb Native on my PC. iLok show it as active; however, I don’t see it in the DAW.  How do I make it appear in the DAW?
      • #143295
        tlongabaugh
          HI rgturner-
          Eventide Plug-ins are installed to the following locations on Windows, please make sure that you have Cakewalk set to look at the appropriate folder (based on if your version of SONAR is 32-bit or 64-bit).
                -VST32: c:Program Files (x86)Common FilesSteinbergVST2Eventide
                -VST64: c:Program FilesCommon FilesSteinbergVST2Eventide
          I'd also suggest doing a rescan of your plug-ins in SONAR.
          Let me know if that doesn't solve your issue.
          -Tom
        • #143301
          rgturner
            Thanks!  I’ll check it later.  After talking with Sweetwater earlier today; they mentioned they same thing.  I don’t purchase a lot of plug-ins (this one is so incredible) and I forgot I had to do the same thing with others in the past.
          • #143307
            rgturner
              Thanks!  All is well.
            • #143326
              tlongabaugh
                Glad to hear you got it worked out, enjoy the plug!
