unable to update
Home › Forums › Products › Rackmount › unable to update
Viewing 4 reply threads
    • #106388
      I just bought a h8000FW, and am trying to update it. I have downloaded the udate to a flash card. When I powering up and hold down #2 it just says "OUPDATE…awaiting contact."
    • #118952
      You have to press and hold the 1 key to engage update from the CFC. The 2 key engages updating from our Windows utility Oupdate, which uses a serial cable to perform the same task.
      all the best
      I
    • #118954
    • #130044
      Hi
      I need to correct my statement as changes have been made.
      The "2" key is the correct one to engage update procedure. It works for both CFC and Oupdate (serial cable + Windows PC). If a card is present it will show up as the priority update method.
      If you are not seeing the update message associated w/the card but the OUPDATE screen is present, then either your card or Pcmcia to CFC adaptor is faulty.
      all the best
      I
    • #118956
      ???? My unit is new out of the box with the factory flash card and adaptor provided. What are you telling me I need to do please…..
