Undulator Attack Envelope tips?
Home Forums Products Plug-Ins Undulator Attack Envelope tips?
    • #116166
      jpleong
      I am trying to print tracks in Ableton Live with the Undulator AU plugin but I cannot get the effect envelope to start consistently.
      I have BPM sync active, I have tried automating both Retrig and Effect On/Off. I have tried automating Tap Tempo in the plug-in but that didn’t actually seem to do anything.
      I feel like this may also apply to other Eventide beat-synced effects (I briefly tried swapping in Ultratap to see if that worked; it did not). As I love the sound of Undulator, any insight would be appreciated!
      JP
    • #156214
      tlongabaugh
      Hi, can you post a screenshot or attach a screenshot of the settings you are using?
      One recommendation – try automating Retrig to be on for about a beat or so, and then automate it off. We've found in some hosts that if you only breiefly automate it to be on (where the automation looks like a sharp peak), then sometimes the automation event is not correctly picked up from the host.
