Home › Forums › Products › Stompboxes › Update H90 firmware
- This topic has 5 replies, 3 voices, and was last updated 2 months ago by raulperez.
November 21, 2024 at 1:48 pm #186426raulperezParticipant
I just updated the firmware on the H90.
I have two problems:1. Before the update I was able to toggle between act/bypass P without any problem with a single press action on my Morningstar MC6. Now it does not always toggle between act and bypass, only some programs toggle, in other programs I have to do two presses to activate.
2. Before the update I had configured a press on the MC6 with the act/bypass action and the mode change (to Perform), that way I activated the H90 and at the same time it changed to Perform Mode (always to the first page). Now every time I execute that action on the MC6 it changes to Perform Mode but each time it does it to a different page, 1 or 2 alternately. It’s great news that page changing can be programmed with midi, but it should be a separate action from entering Perform Mode to avoid accessing a different page each time. I need to always go to page 1 when entering that mode.
If anyone can help me, I would be very grateful.Sorry for my English, I know it’s not very good. Regards!!!
November 21, 2024 at 2:32 pm #186427raulperezParticipant
First problem has been resolved by resetting the conflicting programs.
The second problem depends more on the firmware and the way they have included page toggling in Perform mode. I have tried to delete my message but I can find where.
Apologies. -
November 21, 2024 at 3:07 pm #186429
I just responded to your support ticket but I’ll post my answer here as well for other users to find:
For the Perform Mode command, this was also changed so that users can scroll through the perform mode pages that same way that pressing the Perform Mode knob will do.
When you toggle back and forth from Select and Perform mode, it will remember the last page you were on in Perform mode. You can also save which perform mode page is remembered when you save a Program.
So, if you stay on Perform page 1 and toggle between select/perform, you should find that you always end up on perform page 1. It may be that you have some programs saved that are remembering to jump directly to the perform page 2.
Please try loading a program, going to perform page 1, and then saving the Program. After that, you should find that you can load the program and toggled select/perform mode, and it will remain on page 1.
November 21, 2024 at 4:58 pm #186430raulperezParticipant
Thank you so much!!!
Eventide’s attention is wonderful.
Greetings.
December 4, 2024 at 12:53 am #186640rxguitarsParticipant
what do you mean by resetting the programs ?
December 4, 2024 at 3:07 am #186641raulperezParticipant
Simply do a “save”. The presets save in their configuration the fact of showing the first or second page of “performance mode”. When I made this query I had been using the H90 for two days and I hadn’t noticed.
