update problem
Home Forums Products Stompboxes update problem
Viewing 6 reply threads
    • #106950
      I do not see any accessible update for time factor.
      Update utility says update status: ready for update, but anything is not present in availale update.
      Server problem? l
    • #120154
      achaput
        There may have been a server problem due to the storm. It should be working now.
      • #120160
        Has changed nothing. As was not accessible update so them and is not present
      • #131335
        Hello. Its me, again. Any accessible update and has not appeared in the list.
        Can send file for update?. I has time factor, curent firmware is 2.0.3 (2). My emai: pvaraksin@yahoo.com.
      • #131337
        achaput
          Sorry to hear you are still having trouble. Have you tried the solutions in the following post?
          http://forum.eventide.com/cs/forums/t/5888.aspx
        • #131338
          Hello.
          The case is described not mine.
          The update utility loads, recognizes the Factor pedal. But in that window where there should be a list of accessible firmware of anything is not present. The program communicates with your server normally
          It can be simple will send a file with an firmware?
        • #131380
          I have exactly the same problem. Where can we find the last .bam file for PitchFactor please ?
          Thanks in advance,
          Best Regards.
