Update Question – Bypass
Home Forums Products Rackmount Update Question – Bypass
Viewing 5 reply threads
    • #105314
      enditol
      Question about the update notes please – does this mean we can now Bypass the entire unit via MIDI CC? Thanks!
    • #116887
      IDeangelis
      Eclipse system bypass was already implemented before 3.5.
      Its setting is available under EXTERNALS.
      This new system, V3.5, brings single FX block bypass (a much requested feature). You can now patch a MIDI CC message to any of the 2 FX blocks to engage its bypass.
      Please TRY THIS FUNCTION and check it works flawlessy.
      Thanks
      I
    • #116892
      enditol
      Ah, ok thanks. One more question please: Why does the relay bypass mute the 1/4" outputs? In a guitar rig with FX loop would be nice to be able to bypass the converters without needing another piece of hardware.
    • #127918
      IDeangelis
       Hello
      the manual has this point covered, page 24:
       Relay Byp
      When this is selected, the analog XLR inputs and outputs are connected by a relay (you can hear it click
      when you operate the switch). The digital inputs and outputs are connected electronically, as in DSP bypass.
      The ?? jacks will be muted, so you should not use relay bypass if you are using these jacks. Note that when
      Eclipse is powered down, the same relay connects the analog XLRs, so that signal can pass through.
      Another point is that if you are using an amp FX loop, very likely using the 1/4" is wrong, owing to the signal impedance.
      Most FX loops send out a 0dB/+4dB line level signal wgich the Eventide doesn't handle on 1/4" I/Os. XLRs must be used.
      You can chech our technotes here:
      http://www.eventide.com/AudioDivision/Support/Knowledgebase.aspx
      Connecting Your Eventide Processor to Your Guitar Rig
      Connection and Level Guidelines for XLR and ?" Jacks
      Wiring your Eventide balanced XLRs to unbalanced ??
      best
    • #128062
      bmwm3cs
      You can bypass the converts just setup patch 102 – Thru_Series
    • #128065
      IDeangelis
      Hello
      the only way to bypass the converters is to set SETUP > MODE > BYPASS: Relay Bypass and put Eclipse in BYPASS. This is the true analog bypass mode.
      best
