Home › Forums › Products › Stompboxes › Update Utility doesn’t find my stomps
May 5, 2008 at 1:02 am #105626
slopeshoulder
MemberI've tried this every way. I've even set the stomp manually. TF and MF.
Update Utility never finds them. However they do show up when I ask to to see list of devices.
What going on and please help.
Thanks. -
May 6, 2008 at 3:15 pm #117467
ljholland
MemberI had exactly the same problem. I kept being told to use a different machine. Luckily, I had 4 machines at my disposal….and the 4th one worked.
There's a real bug in the update utility that prevents it from working with most computers. Eventide doesn't seem to be addressing this bug as far as I can tell. There's no reason it should not connect if you're seeing the box in the device manager.
May 6, 2008 at 8:54 pm #117468
GtrWiz
MemberSame problem here, I'm on a Mac OS 10.4.11. this really needs to be addressed.
May 8, 2008 at 3:08 pm #128599
achaput
ModeratorHi guys. We are addressing the issues and we thank you for helping to point these things out. We want the update process to work as much as you want it to (even more??) and we are definitely working on it. Thanks for your patience and for helping us troubleshoot! You guys rock.
Alan
June 12, 2008 at 11:10 pm #128723
GtrWiz
Memberany word on this? I have been unsuccessful on both my Mac and my wife's PC…
June 16, 2008 at 6:44 pm #128754
jnorris
ParticipantOn your PC attempt, when you plugged in the stomps the first time, did you get the add usb device installation? The first time I tried it didn't install the usb device and hence wouldn't find it in the utility. I manually ran the add hardware option, and windows installed the usb drivers. After this it came up in the device manager and then in the utility. They had to email me the bam file, but it ended up working for me. Hope this helps.
June 17, 2008 at 5:47 pm #117597
hagatrp
MemberLikewise. I am on a Mac 10.4.11 and the utility will not recognize the TF.
Any solutions yet?
Thanks
July 31, 2008 at 4:53 pm #117723
SabuJSE
MemberA problem for me as well – and my system does recognize the device as "USB Audio Device".
Very frustrating that I cannot update it,,,
August 4, 2008 at 12:25 pm #117730
Michael Rushing
MemberHave they come out with a Fix yet? I am running mac OSX and am having problems updating it. most of the time it tells me to reboot my device and sometimes it will erase, and load the update and hangs up before it completes the process. weird thing is I don't remember having issues when i updated to the beta version.
August 4, 2008 at 12:44 pm #117731
drooney
MemberHi Michael,
I checked your account and I see that your TimeFactor is showing a successful update completed yesterday to the current version 2.0.3.
Is this correct or do you still require assistance?
August 4, 2008 at 12:57 pm #128876
Michael Rushing
MemberI don't believe it updated since I only have 10 presets. would I not have 20 if it had updated properly?
August 4, 2008 at 1:52 pm #128877
SabuJSE
MemberHi – do we have a rough time fram for a fixed version of the utility? This month, hopefully? Thanks!
August 4, 2008 at 2:43 pm #128878
I think you mean that you only have 10 bank, not 10 presets. If this is what you meant to write, and the update was successful, you would only see the first 10 Banks. When you update only the first 10 Banks are active. Here's what the update notes say:
"Version 2.0 doubles the available space for storing presets. There are
now 20 Banks of two Presets, totaling 40 available Preset slots. Selecting
BANKS in the UTILITY System Menu, you can enable a range of Banks by selecting
the (L)ow and (H)igh BANK. This is useful if you are playing a gig and
you know that you will only need to access a specific BANK range. TimeFactor
ships with 20 unique Factory Presets – the Presets stored in BANKs 11-20
are duplicates of BANKs 1-10. The default setting for the (H)igh BANK
is 10. "In System Mode, in addition to enabling the addiltional Banks, you can display your software version.
October 19, 2008 at 12:06 am #129114
jzucker
Memberi'm having the same problem trying to upgrade from 1.1
October 19, 2008 at 1:01 pm #129116
jzucker
Memberin my case it seems to be related to XP SP3. It works under SP2. Eventide needs to address this but I'm not holding my breath.
October 20, 2008 at 6:24 pm #129117
emfrank72
MemberI just tried to update my Timefactor from 1.1 on OSX 10.5.4 and 2 PCs with XP SP2. On the mac, I get no indication that a device is plugged in. On the PCs it shows a device being plugged in and wants to install software for it. I installed the software on one but not the other. Either way no luck. I tried calling tech support but I guess they don't take calls (grumble grumble) and can only help me through email. This irritates me for a pedal I purchased a few days ago.
October 20, 2008 at 6:43 pm #129118
drooney
MemberHi emfrank,
I have received your email into our support@eventide.com address and I am presently in the midst of following up with you. You will find a response from me shortly.
October 20, 2008 at 6:55 pm #129119
jzucker
MemberThe support folks seem to be confused on this.The one support person who was emailing me kept asking me if the midi backup/restore was working. I kept explaining to him that since the computer wasn't seeing the USB port / timefactor device the midi wouldn't work either. This is really frustrating.
October 20, 2008 at 9:00 pm #129120
achaput
ModeratorHi jzucker,
Sorry for the confusion. What support meant by this is that you can use either TimeFactor's USB port or TimeFactor's MIDI IN and OUT ports to backup sounds as well as to update the OS. If you think that the USB port on your particular unit is faulty then as a matter of troubleshooting you could try the same operation via the stompbox's MIDI ports and see if that works. This requires that you use an external MIDI interface to connect TimeFactor to your computer.
November 13, 2008 at 2:47 pm #129150
pyin1985
MemberHi,
I've just bought mine and I'm having trouble updating it as well. I've 4 machines, 2 with XPSP3, one with XPSP2 and one with vista. They all don't work. Are there any solutions to this problem?
Thanks,
Paul.
