Updated list of memory cards for Eclipse?
Home Forums Products Rackmount Updated list of memory cards for Eclipse?
Viewing 9 reply threads
    • #108837
      wilkinsi
      Couldn't find any of the cards listed in the manual. The smallest capacity I found was 8GB. Anything else was 4GB but the incorrect dimensions.
    • #123540
      8G would be pushing it. Suggest 2G or smaller. There are a huge number on eBay.
    • #123541
      wilkinsi
      I was just reading a thread in the Harmonizers section where someone found an RS232 to USB cable. Naturally, H8000 users will have Vsig. Is it still possible to backup presets from the Eclipse without such a program or a memory card?
    • #134617
      There are various ways to back up programs. A card is probably best – but you can also do a MIDI dump that could probably be received by a number of computer MIDI utilities- see "Dumping Data Via the MIDI and Serial Ports" on UM p.51.
      Note that we cannot suggest such a utility or advise how to use it.
    • #134618
      wilkinsi
      What speed should the card be?
    • #134619
      badmelonfarmer
      the 4GB 30Mb/Sec card I use works fine
    • #134623
      The speed  does not matter – Eclipse assumes that the card is very slow.
    • #134626
      wilkinsi
      I found a 256MB Sandisk CF on wbay for just over £4. Now I just need the lithium battery.
    • #134627
      wilkinsi:
      BR2330 or CR2330, also on eBay. About $2.
    • #134628
      wilkinsi
      Got 2x BR2330'a on ebay for £4. Smile
