Home › Forums › Products › Plug-Ins › updated plugins but there appearing disabled in ableton projects
May 1, 2018 at 11:42 am #114714
Having a little crisis here, Ive updated all my eventide plugins via gobbler and they all work when i open them in a new ableton session BUT they are coming up as disabled in all my projects. I also get this message in the image attached when i open my projects containing instances of Eventide. So to sum up my AU plugins in my projects aren’t opening and can’t be found when i open projects but If i open a new instance of the plugin it runs fine. I believe there must be a path/naming issue that has occured when i updated.
I really need these projects up and running with all the hard work ive done with them, I use eventide alot for sound design so my tunes will never sound the same without the work ive already done.
opperating system: OSX mavericks
Daw: ableton 9
any help would be greatly appreacited!
thanks
Grant
May 1, 2018 at 2:09 pm #149090
Disregard, I have solved the issue. Bloody gobbler!
Thanks..
commonground wrote:Having a little crisis here, Ive updated all my eventide plugins via gobbler and they all work when i open them in a new ableton session BUT they are coming up as disabled in all my projects. I also get this message in the image attached when i open my projects containing instances of Eventide. So to sum up my AU plugins in my projects aren’t opening and can’t be found when i open projects but If i open a new instance of the plugin it runs fine. I believe there must be a path/naming issue that has occured when i updated.
Daw: ableton 9
thanks
Grant
May 1, 2018 at 2:11 pm #149091
Disregard, I’ve solved the issue now.
Thanks
May 1, 2018 at 3:51 pm #149093
Ok, glad you have the issue sorted!
