Updating the Eclipse Using the Compact flash ?
Home Forums Products Rackmount Updating the Eclipse Using the Compact flash ?
Viewing 3 reply threads
    • #105259
      EIII
         I have just seen that there is a Beta OS available for the Eclipse.
        I Can't seem to remember what is the procedure to do on the eclipse when you have copied the files on the card & boot the eclipse.
        I try to remember what is the key to press while booting.
        It is not mentionned anymore on the site, unless i have not found it which is possible.
        Nice site btw !
        Cheers
        Laurent
      • #116769
         Hi Laurent
        thank you for pointing out the info is missing on the new website!
        We are still working on it, obviously ;-))
        The card updating procedure requires to press & hold the 1 key at power up.
         …as you have already found out!
        cheers
      • #116770
        Hi there !
        I also tried to update my Eclipse with the new OS. Problem is : I have a standard Compact Flash 2Gb card and the manual ask to download an utility called "Card upgrade" because the compact flash need to be specially encoded. Anyway I can't find this "Card upgrade" anywhere on the Eventide Website, do you know where I can get it ?? Thanks a lot !!!
        Julien, France
      • #127829
         Hi Julien
        I advice you to not get 3.5 yet as it is incomplete. It's under beta and misses some functions.
        best
