Upgrading H9000R firmware from 1.4 (beta tester 2.0)
Home Forums Products Rackmount Upgrading H9000R firmware from 1.4 (beta tester 2.0)
Viewing 6 reply threads
    • #116599
      J20056
        I was a beta tester for Emote 2.0 and as I try to upgrade to the public version, I have to update the firmware to 2.0 from 1.4.0[4]. When I try to do it via Emote, I do see the list of available firmware version, including 2.0.0.3, but as I try to install it, I get an error saying “Emote cannot update this H9000R because its firmware is out of date. Please update your unit to the latest firmware using a USB updater. Alternatively, you can upgrade your H9000R using Emote version 1.3.”
        Can someone provide EXACT instructions on what I need to do, as I am nervous that the above may or not work. I was hoping to never have to worry about this with 2.0, and hopefully this is the last time, but help appreciated.
        Regards
      • #158348
          J20056 wrote:
          I was a beta tester for Emote 2.0 and as I try to upgrade to the public version, I have to update the firmware to 2.0 from 1.4.0[4]. When I try to do it via Emote, I do see the list of available firmware version, including 2.0.0.3, but as I try to install it, I get an error saying "Emote cannot update this H9000R because its firmware is out of date. Please update your unit to the latest firmware using a USB updater. Alternatively, you can upgrade your H9000R using Emote version 1.3."
          Regards
          Sorry for the confusion with this. The H9000 firmware version you are on is not compatible with the new Emote update method, so that's why you are getting the error message.
          You have 2 options to update:
          1. Update to latest firmware using USB firmware installation: https://cdn.eventideaudio.com/manuals/h9000/content/appendix/startup_seq.html#fail-safe-updater-recovery-mode
          2. Download/Install Emote 1.3: https://www.eventideaudio.com/support/product/14445/installers
          Update your H9000 to the latest firmware using Emote 1.3, then download/Install Emote 2.0 and you should be all set.
          Once your H9000 is on the latest firmware, you will be able to use the new update method for future updates. Sorry for the inconvenience and let me know if you have any issues.
        • #158370
          J20056
            This seems easier: Download/Install Emote 1.3: https://www.eventideaudio.com/support/product/14445/installers
            However, importantly, does that Emote version work with the 1.4.0[4] firmware?
          • #158371
              Yes, you'll be able to connect to Emote 1.3 with your H9000 on FW version 1.4
              Keep in mind that you will need an internet connection directly to the H9000 via ethernet or Wi-Fi to see the updates when using Emote 1.3, so depending on how your H9000 is connected to your computer, the USB method may be a better solution.
            • #158373
              J20056
                It doesn’t work with Emote 1.3. Clicking on Updates shows an empty window.
                Here we go again… I really hope this is the last time with this disgrace. I guess I have to try the USB route
              • #158374
                J20056
                  USB method fails as I cannot connect to the recovery drive. Can we set up a phone call to get this done before the weekend so I can use my now-idle unit? This is really unbearable
                • #158375
                  J20056
                    never mind. USB up[date worked. TY.
