Home › Forums › Products › Stompboxes › US purchased Space, powered by UK purchased Pawer bank
August 29, 2014 at 7:09 pm #111882
Hi there,
I'm looking at buying an Eventide Space when i visit the US next month. I'm a FOH engineer and run a few stompboxes powered by a Decibel 11 Hot Stone Deluxe (which power Eventide pedals) which fits neatly in a rack drawer i use with other rack effects and comps.
I realise if i were to use the eventide power supply i would need a step down transformer to power in the UK, but would it run straight off the Hot Stone if i wasn't to use the Eventide power supply? Is it just the power supply that requires the transformer or is the Space looking for 110v also?
Thanks in advance.
August 29, 2014 at 7:20 pm #126607
The Eventide official line is they can only advise the official Eventide Power supplies … which you can understand.
However, they will run with other power supplies, the OneSpot with an L6 converter works … you can also buy an official UK spec Eventide power Supply.
Basically a decent 9V DV Boss Style + a OneSpot L6 converter will work as long as it puts out 500mA or above … oh and don't daisy chain the power supplies … you need to keep them isolated.
interestingly the US H9 PSU is worldwide voltage and I use the 3 I bought from the US with a 3 pin to Shaving socket … when not using the Eventide PowerFactor.
Hope that helps
August 29, 2014 at 7:24 pm #126608
So basically, it will run on different voltages between the US and UK providing i have the correct power supply?
The Hot Stone is great. Like a Voodoo Labs Pedal Power 2 but with the capability of powering a larger variety of pedals and cheaper as well. I'll be using a Step down Transformer for that whilst i'm in the states.
August 29, 2014 at 7:27 pm #126609
Actually looking at the Decibel webpage … you can run the Space at 12V DC with a "2.5mm Center Positive Cable "
From the Decibel website it links to this Amazon page… http://www.amazon.com/gp/product/B00IRJ619U
I know I said 9V DC 500mA … but they can run at 12V DC @ 400mA … (that is what the PowerFactor runs them at 😉
August 29, 2014 at 7:29 pm #126610
Yeah it's the same as the Line 6 DL4 which it powers without a problem.
August 29, 2014 at 7:32 pm #137267
grant2b:
The Space Pedal will need 9 or 12v DC … so you will need to use a PSU to convert whatever the country you are in down to 9 or 12v… OneSpot or PowerFactor will do this…. Maybe the Decibel can? don't know as I have not used one … actually looking at the Decibel web site NO it can't …there is a European and a North American version… so you would need a step down transformer if using the US Version in the UK and a Step UP transformer UK version in the US.
August 29, 2014 at 7:38 pm #137268
grant2b:
you will be fine then
