USB Cable for Modfactor
Home Forums Products Stompboxes USB Cable for Modfactor
    • #106875
      wpaone77
      Anyone know if this cable should have been included?  If not, what would you recommend and where should I buy it?  I know it requires a type B 2.0 USB instead of the standard USB interface connection.  Thanks in advance.
      Sincerely,
      Eager to Update
    • #120004
      The USB cable is not included with the 'Factor because it is a totally standard, widely available part.
      This cable is known in USB parlance as an A-B type, meaning it has one square-ish connector, and one flat one. The connectors should be standard size, not the mini type used by many cameras and mice.
      It does not need to be specified for USB 2.0 – pretty much any cable will work. Anyone who has a computer will probably have a few.
