USB Input from Electric Drum Kit
Home Forums Products Rackmount USB Input from Electric Drum Kit
Viewing 3 reply threads
    • #172693
      gustebeast
        I am trying to decide on an electric drum kit to get. I was hoping to find one with an optical output to send to the H9000 but I can’t seem to find one. Nearly all of them have USB output though. Would it be possible to use that with the H9000? Would I have to use the type B port on the back of the H9000 or could I use one of the type A ports? I’d like to avoid the type B port because that’s how my H9000 communicates with my computer. Ideally I could have that connected for recording while having the drums sending signal to the H9000.
      • #172698
        gustebeast
          Resolved: https://cdn.eventideaudio.com/manuals/h9000/2.0/content/hardware/9kfrontpanel.html#usba
          Looks like I would have to use the B port and even then no guarantee it would be compatible
        • #172705
          Puppeteer
            Audio over USB to the H9000 is unlikely to work except from a computer using Eventide’s driver.
            You would be better off sending audio via analog outputs to the H9000’s analog inputs.
          • #172706
            gustebeast
              Agreed. It would be cool though if the usb A ports could be used for this
