Hi, I have a Boss FV500H that I’d like to use as an expression pedal for my newely purchased H9. Te pot value is 10k so it should be fine.
However, I find that the sweep is not quite perfect: for quite a bit of the sweep the value stays at minimum and it never reaches the max value, arriving just short at 94 out of 99 (when I try to control something like intensity).
Is there some sort of “fix” for this?
